[postgis-devel] [PostGIS] #1357: Use gbox_overlap where appropriate
PostGIS trac at osgeo.org
Thu Dec 8 13:08:58 PST 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 In r8323 a manually crafted "box overlap" is implemented. It would be less
 error prone to use the existing gbox_overlaps instead. Paul mentioned
 there are more such cases. Worth cleaning them up. And making sure the
 cunit tests are in place for that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1357>
