[postgis-devel] [PostGIS] #1357: Use gbox_overlap where appropriate
PostGIS trac at osgeo.org
Fri Dec 9 03:18:57 PST 2011
  Reporter:  strk     |       Owner:  strk
      Type:  task     |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 As of r8331 I added a gbox_overlaps_2d and used that within lwgeom_geos.c
 where appropriate.
 I noticed there's a need for gbox_contains_2d as well but isn't available
 for gbox, only for box2df inside gserialized_gist_2d. May be worth
 exporting to higher levels.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1357#comment:2>
