[postgis-devel] [PostGIS] #1360: Update new_postgis_restore.pl
PostGIS trac at osgeo.org
Mon Dec 12 07:49:05 PST 2011
  Reporter:  strk     |       Owner:  strk
      Type:  task     |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 With r8361 this script is pretty complete. There are still problems with
 user views making use of obsoleted functions. The only way to fix those
 would be to have a script to prepare a database prior to upgrade, making
 sure to drop dependency on deprecated function before dumping. Such step
 would also need to clean up the unknown SRID usage and constraints.
 Worth a separate ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1360#comment:3>
