[postgis-devel] [PostGIS] #1368: ERROR: operator does not exist: hstore @ hstore
PostGIS trac at osgeo.org
Mon Dec 12 08:02:19 PST 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 The *postgis_restore.pl family of function try to avoid restoring items
 which may have been installed by postgis, but for operators the custom
 dump manifest doesn't contain enough information to tell if an operator
 belongs to postgis or not.
 In this case, the hstore module installs a few operators which have the
 same name as the ones we use for spatial types, thus *postgis_restore.pl
 traps them and you end up with those operators not clearely restored.
 Not necessarely a big deal, if you can restore those by re-enabling hstore
 in your db, but they could be used by other items in your dump (views?)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1368>
