[postgis-devel] [PostGIS] #1362: Remove lwgeom_gist.c
PostGIS trac at osgeo.org
Mon Dec 12 09:56:04 PST 2011
  Reporter:  pramsey  |       Owner:  strk
      Type:  task     |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by strk):
 Is it supposed to drop things which are _not_ in postgis.sql ? In this
 case references to operators using the old signatures in lwgeom_gist
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1362#comment:4>
