[postgis-devel] [PostGIS] #1369: [raster] raster2pgsql missing help version info
PostGIS trac at osgeo.org
Mon Dec 12 20:14:15 PST 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  low             |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 Bborie,
 Just noticed the help screen on raster2pgsql when I run doesn't give any
 info like revision number etc.  This has been helpful in the past when
 people have issues debugging what they are running.
 For example shp2pgsql gives this info in help
 RELEASE: 2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1 (r$Id: shp2pgsql-co
 -08-09 09:51:52Z strk $)
 USAGE: shp2pgsql [<options>] <shapefile> [[<schema>.]<table>]
 I'm not seeing similar info for raster2pgsql
 Granted we may loose some of that detail when we move to git.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1369>
