[postgis-devel] [PostGIS] #1371: postgis_restore.pl: insert or update on table "layer" violates foreign key constraint "layer_topology_id_fkey"
PostGIS trac at osgeo.org
Tue Dec 13 10:01:49 PST 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 Ok, here's the thing:
 the _definition_ of layer and topology tables comes from the topology.sql
 script, not from the dump. This means it is equipped with constraints.
 If we restored the tables from the dump we'd get the constraints added
 later and so wouldn't
 break them.
 I guess this was a problem with geometry_columns as well before it became
 a view.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1371#comment:2>
