[postgis-devel] Path from constrained to typmod'ed definitions
Sandro Santilli strk at keybit.net
Tue Dec 13 14:47:58 PST 2011
On Tue, Dec 13, 2011 at 04:41:16PM -0500, Paragon Corporation wrote:
> On second thought that will fail if they have views unless you can ensure
> the views get built after you run populate_geometry_columns().
What would fail with views ? There's no way in 2.0 to get geometry_columns
correct with view definitions missing typmod.
--strk;
  ,------o-.
  |   __/  |    Thank you for PostGIS-2.0 Topology !
  |  / 2.0 |    http://www.pledgebank.com/postgistopology
  `-o------'
