[postgis-devel] [PostGIS] #1045: TopologyException if I don't use ST_Dump to resolve single geometries before I do ST_Intersection
PostGIS trac at osgeo.org
Fri Dec 16 09:25:32 PST 2011
  Reporter:  laopsahl    |       Owner:  pramsey
      Type:  defect      |      Status:  closed
  Priority:  medium      |   Milestone:  PostGIS 1.5.4
 Component:  postgis     |     Version:  trunk
Resolution:  worksforme  |    Keywords:  TopologyException ST_intersection ST_Dump
Comment(by laopsahl):
 Her is the output, I use a older geos and a older postgis.
 POSTGIS="1.5.3" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
 2009" LIBXML="2.6.26" USE_STATS
 (1 row)
 Seems like I have to start to test postgis 2.0.
 I just leave the bug closed and I will reopen it if fail's with postgis
 2.0, but it seems to work for you.
 Thanks Lars
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1045#comment:5>
