[postgis-devel] [PostGIS] #1382: Some addresses take a long time to geocode or normalize
PostGIS trac at osgeo.org
Sat Dec 17 14:31:40 PST 2011
 Reporter:  raviada         |       Owner:  robe
     Type:  defect          |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Ravi,
 1) Download the latest postgis 2.0 tar ball or if you have svn svn update
 your postgis.
 2) I fyou are on linux/unix edit and run the
 tiger_2010/upgrade_geocoder.sh, for windows there is a similar
 upgrade_geocoder.bat file.
 Then you should be up to date.
 Brian,
 Yes I was using mostly limit 1 but not all the time. Limit 1 tends to
 perfrom better than all but it varies a lot how much better it is but the
 speed is usually equal to or better.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1382#comment:5>
