[postgis-devel] [PostGIS] #1382: Some addresses take a long time to geocode or normalize
PostGIS trac at osgeo.org
Sat Dec 17 21:02:45 PST 2011
 Reporter:  raviada         |       Owner:  robe
     Type:  defect          |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Ravi,
 Okay that seems to agree with around what I am getting for that address.
 I get 19 seconds for no limit and 18 seconds for limit. But the address it
 returns is completely wrong.  I'll put in a separate ticket for this.  I
 think it might be the Astoria throwing it off.
 since if I run this:
 select pprint_addy(addy), ST_AsText(geomout), rating FROM geocode('2601
 24TH AVE,  NY 111022337',2);
 -- it returns this:
 0 24th Ave, New York, NY 11102  POINT(-73.9184479285714 40.7744440102041)
 15
 Which is much more accurate.
 If I reverse geocode:
 -- answer tiger geocoder is returning (with Astoria)
 SELECT pprint_addy(addy[1]),  array_to_string(street, '|') from
 reverse_geocode('POINT(-73.9750505 40.613036)', true) As g;
 6148 24th Ave, NY 11204 1404 - 1416 Dahill Rd|2301 - 2399 62nd St
 -- to rule out a tiger data issue, I reverse geocoded what google returns.
 -- though the place seems suspiciously missing, thought that could be a
 reverse geocode issue.
 SELECT pprint_addy(addy[1]),  array_to_string(street, '|') As
 cross_streets from reverse_geocode('POINT(-73.918402 40.774441)', true) As
 g;
 2607 24th Ave, NY 11102 2301 - 2399 26th St|2300 - 2398 27th St
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1382#comment:9>
