[postgis-devel] [PostGIS] #1385: ST_Extent() segfaults on null geometries
PostGIS trac at osgeo.org
Sun Dec 18 04:06:47 PST 2011
 Reporter:  rouault   |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 The following sequence causes a crash in BOX3D_combine(), line 348, on
 "GSERIALIZED *geom = (GSERIALIZED*)PG_DETOAST_DATUM(PG_GETARG_POINTER(1))"
 CREATE TABLE test_crash_st_extent ( foo VARCHAR )
 SELECT
 AddGeometryColumn('public','test_crash_st_extent','wkb_geometry',0,'GEOMETRY',2)
 INSERT INTO test_crash_st_extent (foo) VALUES ('bar')
 SELECT ST_Extent(\"wkb_geometry\") FROM test_crash_st_extent
 Attached patch fixes the segfault
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1385>
