[postgis-devel] [PostGIS] #1350: [raster] GDALPolygonize not being set to 1 when compiling with GDAL 1.9
PostGIS trac at osgeo.org
Sun Dec 18 09:12:47 PST 2011
  Reporter:  robe            |       Owner:  dustymugs
      Type:  defect          |      Status:  closed
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:  mingw
Changes (by robe):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Bborie,
 Thanks -- setting the LDFLAGS environment variable seems to do the trick.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1350#comment:12>
