[postgis-devel] [PostGIS] #1367: Provide a clear upgrade path to 2.0
PostGIS trac at osgeo.org
Mon Dec 19 01:10:10 PST 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 With r8468 the postgis_restore.pl script also takes care of
 spatial_ref_sys by restoring all entries in dump with SRIDs not found in
 pre-existing spatial_ref_sys table, thus allowing you to decide which
 version of the core srid you want (you probably want the new ones).
 This means that step 2 in the first comment (spatially-enable new
 database) could now include sourcing spatial_ref_sys.sql w/out worrying
 about getting a zilion "duplicate primary key" errors at restore time.
 I guess all is left here is documenting the procedure and calling for
 test.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1367#comment:6>
