[postgis-devel] [PostGIS] #1391: postgis errors during upgrade of old db
PostGIS trac at osgeo.org
Tue Dec 20 06:11:45 PST 2011
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 strk,
 Here are the errors I see in the db I moved over from my PostgreSQL 8.4
 windows 2003 PostGIS 1.5 (32-bit) -> windows 2008 64-bit PostGIS 2.0
 (running 32-bit PostGIS/PostreSQL 9.1).
 they might all be expected but the intructions say I should not be getting
 errors.  Note: I intentionally did not install the legacy.sql fully
 expecting that the script would not try to restore old deprecated
 functions so some of these might be the result of sql/plpgsql user
 functions not being able to find old ones.  I suspect though that many of
 these are postgis packaged ones since most of these I don't recall ever
 using in my code on this db.
 This is a database that has been upgraded many times since pre-1.0 and was
 currently 1.5.3.
 See attached file.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1391>
