[postgis-devel] [PostGIS] #1390: postgis_upgrade.pl should skip postgis function comments
PostGIS trac at osgeo.org
Tue Dec 20 07:04:22 PST 2011
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by strk):
 The best way to fix this is by obtaining a log of a postgis_restore.pl run
 in presence of comments in the dump. You can get such log by passing the
 -v switch to postgis_restore.pl and redirecting its standard error to a
 file, then grep for '^KEEP.*COMMENT' into the log.
 I don't have a dump with comments. Can make up one but one with comments
 from 1.4 and/or 1.5 would be even better.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1390#comment:1>
