[postgis-devel] [PostGIS] #1392: Can't geocode an intersection that should work
PostGIS trac at osgeo.org
Tue Dec 20 12:53:32 PST 2011
 Reporter:  arencambre      |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
 The attached image is a sample from the '''tiger_data.tx_edges''' table as
 viewed in Quantum GIS.
 You can clearly see that '''N Denton Tap Rd''' intersects '''State Hwy
 121'''. However, these queries produce no results:
 SELECT * FROM geocode_intersection('State Hwy 121', 'N Denton Tap Rd',
 'TX', 'Coppell');
 'TX');
 This geocoder was constructed using the instructions at
 [http://www.letseehere.com/postgis-geocoder-using-tiger-2010-data] but
 only using Texas data. This intersection is in Coppell, Dallas County, TX.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1392>
