[postgis-devel] [PostGIS] #1393: Evaluate use of GUC for postgis
PostGIS trac at osgeo.org
Wed Dec 21 02:51:47 PST 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Note that the need to modify postgresql.conf would require the testing
 framework to create its own database cluster for the sake of having a
 controlled configuration. The same is true for avoiding localized messages
 or other things controllable by config (like default schema name).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1393#comment:1>
