[postgis-devel] pgraster: st_resample error
Tom van Tilburg tom.van.tilburg at gmail.com
Thu Dec 22 07:08:13 PST 2011
Hi all,
Can anyone tell me if it's me or postgis making the mistake.
Bottom line is that st_resample from epsg 28992 to 900913 gives me
offsets of around 20 kilometers in Y direction.
===SQL=======
WITH
raster As (
     SELECT  ST_AddBand(ST_MakeEmptyRaster(100, 100, 195000, 450000, 1,
1, 0, 0, 28992),'32BUI')  As rast
sub As (
     SELECT ST_Transform(ST_SetSrid(ST_Extent(ST_Resample(rast,
900913)),900913),28992) geom FROM raster
sub2 As (
     SELECT ST_Transform(ST_Transform(ST_SetSrid(ST_Extent(rast),
28992), 900913), 28992) geom FROM raster
SELECT 'st_resample' As class, ST_Extent(geom)::Text FROM sub
UNION
SELECT 'st_transform' As class, ST_Extent(geom)::Text From sub2
UNION
SELECT 'original' As class, St_Extent(rast)::Text FROM raster
===RESULT======
"st_resample";"BOX(195165.982320333 429216.850820453,195268.212183354
429318.822637769)"
"st_transform";"BOX(195000.000157893 450000.000438874,195100.000157985
450100.000438936)"
"original";"BOX(195000 450000,195100 450100)"
===spatial_ref_sys====
28992: "+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel
+towgs84=565.237,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0812
+units=m +no_defs "
900913: "+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"
