[postgis-devel] [PostGIS] #301: [raster] Add uninstall_rtpostgis.sql machinery
PostGIS trac at osgeo.org
Thu Dec 22 13:58:50 PST 2011
 Reporter:  mloskot                |       Owner:  robe
     Type:  enhancement            |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by dustymugs):
 Attached bash script to generate uninstall sql files for postgis and
 raster.  As attached, script runs from raster/rt_pg.  Generated uninstall
 files appear to work for a clean data loaded with postgis.sql and
 rtpostgis.sql.
 At least on PostgreSQL 9.0, the order of DROP statements isn't perfect for
 TYPEs and any dependent functions as the DROP TYPE uses CASCADE.
 I'll attach the uninstall files.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/301#comment:10>
