[postgis-devel] [PostGIS] #1409: Can't compile topology or raster anymore under mingw
trac at osgeo.org
Sun Dec 25 12:07:06 PST 2011
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by robe):
Okay I think I figured out my issue with raster. strk it's this line you
added to rt_pg/Makefile.in
http://trac.osgeo.org/postgis/browser/trunk/raster/rt_pg/Makefile.in#L92
# SQL objects deps here
$(SQL_OBJS): ../../postgis/sqldefines.h
Wouldn't that overwrite this?
$(SQL_OBJS): %.in: %.in.c
$(CPP) -I../../postgis/ -I../../ -traditional-cpp $< | grep -v
Should that other part go in ${OBJS} instead.
I realized I don't know quite what I'm talking about but getting rid of
that line you added fixes my compile issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1409#comment:3>
