[postgis-devel] pgraster: st_resample error
Bborie Park dustymugs at gmail.com
Tue Dec 27 16:57:26 PST 2011
Hey Tom,
I'm basically wondering if for a latitude/longitude, the value at that
coordinate is correct regardless of projection.
-bborie
On Tue, Dec 27, 2011 at 8:06 AM, Tom van Tilburg
<tom.van.tilburg at gmail.com> wrote:
> Bborie,
> Sorry for checking up a bit late on the subject. Christmas was a busy time.
> I'm not sure if I understand you correct about being 'geographic correct'.
> Could you elaborate a bit more? I'm not very known to raster processing.
> If you wonder whether data inside the image is correct: yes it is. When I
> display the image I see it as expected, but on a different position.
> Cheers,
>  Tom
> On 24-12-2011 2:01, Bborie Park wrote:
>> Tom,
>> I do have a question though.  Regardless of the transformed extent,
>> have you check the warped rasters to see if the data for a geographic
>> point is correct?  Correct being subjective as a warped raster is
>> resampled from the original raster to the new projection.
>> -bborie
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
