[postgis-devel] [PostGIS] #1404: [raster] raster2pgsql overviews don't look right
PostGIS trac at osgeo.org
Tue Dec 27 17:32:44 PST 2011
  Reporter:  robe            |       Owner:  pracine
      Type:  defect          |      Status:  reopened
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:
Comment(by dustymugs):
 Yes.  You are correct.  Something is up with the INSERT version.  Unlike
 the COPY version that has no issues, the INSERT version has constraint
 issues.
 I'm using the following:
 COPY
 boston_test7 > copy.sql
 INSERT
 boston_test8 > insert.sql
 BUT if I remove the overview switch from the INSERT statements loader, the
 constraint errors go away.
 I'll do some debugging.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1404#comment:18>
