[postgis-devel] [PostGIS] #1409: Can't compile topology or raster anymore under mingw
PostGIS trac at osgeo.org
Wed Dec 28 02:55:32 PST 2011
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by strk):
 Theoretically no, there should be no override, the latter should be only
 encoding an additional dependency. I guess it depends on make version. It
 is meant to force rebuild of the SQL file when changing sqldefines, which
 in turn is changed by ./configure
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1409#comment:6>
