[postgis-devel] Tested postgis_restore.pl
Sandro Santilli strk at keybit.net
Wed Dec 28 14:16:32 PST 2011
On Wed, Dec 28, 2011 at 01:29:16PM -0800, dustymugs wrote:
> On 12/28/2011 01:04 PM, 'Sandro Santilli' wrote:
> >On Wed, Dec 28, 2011 at 11:06:28AM -0800, Bborie Park wrote:
> >>The default search_path is: userland, postgis, contrib
Your database default ?
> >>On the whole, the script works.  But I'm finding that two PostGIS
> >>1.5 functions are getting through to the userland schema.
> >Only _after_ the call to postgis_restore.pl ?
> Correct.
Could you please pass the -v switch to postgis_restore.pl and
save stderr in a file ? It'd have a log of kept/skipped items.
> >I guess the only way to do that would be dropping the
> >'SET search_path' produced by pg_restore, right ?
> For my setup, I have to alter the search_path to include the other
> two schemas.
Are you modifying the output of postgis_restore.pl ?
How ? And why ?
--strk;
  ,------o-.
  |   __/  |    Thank you for PostGIS-2.0 Topology !
  |  / 2.0 |    http://www.pledgebank.com/postgistopology
  `-o------'
