[postgis-devel] [PostGIS] #1420: ST_LocateBetween(geom, m1, m2, offset)
PostGIS trac at osgeo.org
Fri Dec 30 05:17:20 PST 2011
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 Add in an LRS function using SQL/MM function naming, replaces and enhances
 SE_LocateAlong currently in SQL/MM package. Offset allows derived geometry
 to be offset to left or right of parent.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1420>
