[postgis-devel] [PostGIS] #657: Spheroid/Ellipsoid projection given Lat/Lon, Distance & Bearing
PostGIS trac at osgeo.org
Fri Dec 30 15:08:54 PST 2011
  Reporter:  lwilmen      |       Owner:  pramsey
      Type:  enhancement  |      Status:  reopened
  Priority:  critical     |   Milestone:  PostGIS 2.0.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:  bearing distance liblwgeom spheroid ellipsoid
Changes (by pramsey):
  * status:  closed => reopened
  * version:  1.5.X => trunk
  * resolution:  fixed =>
Comment:
 Oops, am I exposing radians? I want to only work with degrees at a user
 level. Sound good? And looks like ST_Project needs to normalize the
 outputs before returning.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/657#comment:6>
