[postgis-devel] [PostGIS] #1305: ST_Azimuth on the spheroid
PostGIS trac at osgeo.org
Fri Dec 30 19:00:39 PST 2011
  Reporter:  realityexists  |       Owner:  pramsey
      Type:  enhancement    |      Status:  reopened
  Priority:  medium         |   Milestone:  PostGIS 2.0.0
 Component:  postgis        |     Version:  1.5.X
Resolution:                 |    Keywords:
Comment(by robe):
 oh I meant degrees function.  e.g.
 SELECT degrees(ST_Azimuth(ST_Point(25,45), ST_Point(75,100))); -- 42.273
 I probably should change the docs to use that function since its easier to
 write and remember and that function has existed in postgres for eons.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1305#comment:6>
