[postgis-devel] [PostGIS] #823: tiger geocoder: Make loader_generate_script download portion less greedyy
trac at osgeo.org
Wed Feb 9 21:10:58 PST 2011
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: tiger |
The current loader_generate_script function is a bit greedy in its wget
calls. For each state it downloads all the census data for that state.
Most of these tables like water, census blocks, faces_al/ah aren't even
used for geocoding.
It should only download the tables that fit the pattern of the tables in
the loader_lookuptables (where load=true) since these are the only ones
that are processed by the loader. This will allow people to add
additional tables for processing if they care to, but also minimize on
unnecessary waiting for files that aren't even used to be downloaded.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/823>
