[postgis-devel] [PostGIS] #830: ST_UnaryUnion
PostGIS trac at osgeo.org
Mon Feb 14 09:38:33 PST 2011
#830: ST_UnaryUnion
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:
 Keywords:               |
Comment(by strk):
 r6816 contains implementation and testing.
 Misses docs.
 Notable things for the documentation:
 * ST_UnaryUnion(<invalid_polygon>) will not give you a valid polygon, but
 return the input untouched
 * UnaryUnion unions the _components_ of a geometry, assuming each
 component is valid
 * ST_UnaryUnion(ST_Collect(the_geom)) is equivalent to ST_Union(the_geom)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/830#comment:2>
