[postgis-devel] [PostGIS] #791: Topology: function GetEdgeByPoint($1, $2, $3)
PostGIS trac at osgeo.org
Mon Feb 14 12:20:04 PST 2011
#791: Topology: function GetEdgeByPoint($1,$2,$3)
 Reporter:  aperi2007    |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by aperi2007):
 hi Robe,
 if is ok.
 I will use a new file named <function>_code.sql for declaring each of
 these two functions instead of apply directly into the populate.sql file ?
 for example:
 GetEdgeByPoint will have these 4 files
 GetEdgeByPoint_code.sql (the function definition)
 GetEdgeByPoint.xml (the doc)
 GetEdgeByPoint.sql (the regress test)
 GetEdgeByPoint_expected (the results expected)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/791#comment:10>
