[postgis-devel] [PostGIS] #833: PostGIS 2.0 Testing on various desktops
trac at osgeo.org
Tue Feb 15 23:20:07 PST 2011
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by nicklas):
In QGIS this is solved in QGIS trunk (QGIS 1.7). They have nightly builds
that I use.
But quite annoying is that nightly build id built against Gdal 1.6.x but
QGIS 1.6 is built against 1.7.x for Ubuntu. Have not successed to use the
raster plugin with any of the versions. load raster to db works, but I
have not been able to view the data in QGIS.
For gvSig there is also some trouble in 1.10 not passing the z-values. I
had a patch from the developers to try 3D-extension. After some help from
them I had it working. About ST_Asbinary I don't know if this was before
AsBinary was removed or if it was fixed in that patch. The z-issue should
hopefully be fixes in release 1.11.
I also had some troubles with connections hanging after I had removed the
table from gvSig.
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/833#comment:2>
