[postgis-devel] GML3 output signatures
Olivier Courtin olivier.courtin at oslandia.com
Tue Feb 22 01:36:26 PST 2011
On Feb 22, 2011, at 10:06 AM, Sandro Santilli wrote:
> I'm planning to change the gml3 output function signatures
> to merge the current is_dims and is_degree arguments into
> a single bitfield, to allow for future expansion of the flags
> (in particular to add LineString vs. Curve representation [1]).
> Does anyone have problems with it ?
> [1] http://trac.osgeo.org/postgis/ticket/816
Naive question, but why do you need to do that ?
The option parameter (already a bit field) should be enough isnt'it ?
Olivier
