[postgis-devel] GML3 output signatures
Olivier Courtin
olivier.courtin at oslandia.com
Tue Feb 22 01:43:35 PST 2011
On Feb 22, 2011, at 10:36 AM, Olivier Courtin wrote:
>> I'm planning to change the gml3 output function signatures
>> to merge the current is_dims and is_degree arguments into
>> a single bitfield, to allow for future expansion of the flags
>> (in particular to add LineString vs. Curve representation [1]).
>> Does anyone have problems with it ?
>> [1] http://trac.osgeo.org/postgis/ticket/816
> Naive question, but why do you need to do that ?
> The option parameter (already a bit field) should be enough isnt'it ?
Hum after have a look on the code, i understand the aim.
And yes it's fine to me to have only a single bitfield on the prototype.
Olivier
