[postgis-devel] [PostGIS] #845: ST_Intersects() precision error - returns false instead of true
PostGIS trac at osgeo.org
Thu Feb 24 04:46:02 PST 2011
 Reporter:  cdestigter  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  postgis     |     Version:  1.5.X
 Keywords:              |
Comment(by nicklas):
 strk, you are right, pt_in_ring is counting crossings.
 As I understand now we have different point in polygon code in 4 places
 1) point_in_ring (winding number)
 2) pt_in_ring (crossing number)
 3) pt_in_ring_3d (winding number)
 4) There is also some implementation for geography somewhere (crossing
 number I think from a discussion some time ago)
 The geography implementation have to be separate of course.
 All the three others can be more or less merged.
 I have not studied winding number enough to understand it. But at the
 softsurfer link above that is what they recommend.
 My reason for rewriting the iterations in 3d-version even if it is the
 same thing happening as 2d-version is that it gets quite messy if I
 project the polygon to, say x-z plane instead of x-y since x and y is hard
 coded in the functions. If we can write the function so it just takes
 coord1 and coord2 instead of x and y it can be used more widely.
 How is that done in a robust way.
 In other words, is this possible to do in some efficient robust way?
 coord1=x;
 pt.coord1;
 instead of
 pt.x;
 a macro can do that?
 Will it be to ugly (unefficient) or is it worth it to share more code?
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/845#comment:11>
