[postgis-devel] [PostGIS] #845: ST_Intersects() precision error - returns false instead of true
PostGIS trac at osgeo.org
Thu Feb 24 07:31:31 PST 2011
 Reporter:  cdestigter  |       Owner:  strk
     Type:  defect      |      Status:  assigned
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  postgis     |     Version:  1.5.X
 Keywords:  history     |
Comment(by strk):
 +1 for moving to liblwgeom
 +1 for putting under unit testing
 wouldn't change anything until things are regress-tested.
 Oh, while porting to 1.5 I've seen the _same_ bug is in
 point_in_ring_tree.
 Should I blindly fix that as well or leave alone ? Did you mention it is
 unused ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/845#comment:36>
