[postgis-devel] [PostGIS] #846: Cleaning up around and enhance point in polygon tests around the code
PostGIS trac at osgeo.org
Thu Feb 24 14:10:09 PST 2011
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by nicklas):
 Hmm, I did forget the fifth point in polygon. The point_in_polygon_rtree.
 Does anyone know if that for some reason is called from outside so Doxygen
 doesn't see it. If so, I guess that should be left in postgis folder and
 only move point_in_polygon.
 BTW, I see Doxygen thinks that one of the 3d distance functions calls
 point_in_polygon because I have used intersects as variable name. see the
 graph in the bottom of this link:
 [http://postgis.refractions.net/documentation/postgis-
 doxygen/de/dd0/lwgeom__functions__analytic_8c_ac03a9d336c58e8ca7b35195ba20513c.html#ac03a9d336c58e8ca7b35195ba20513c]
 Is that only a doxygen problem or should I change variable name?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/846#comment:5>
