[postgis-devel] [PostGIS] #833: PostGIS 2.0 Testing on various desktops
trac at osgeo.org
Fri Feb 25 14:29:40 PST 2011
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Old description:
> Desktops to test - just itemizing issues so far that we need to address
> before release (either with an FAQ workaround or get the developers of
> these to revise)
> GvSig -- I know already gvSig 1.10 doesn't work with PostGIS 2.0 -- looks
> like they are using AsEWKB which I pulled out.
> Others to test
> uDig -
> QGIS 1.5 seems to work okay with 2.0
> OpenJump (I have just 1.3.1 need to check newer)-- Ad hoc Query tool
> works okay but Data Store layer doesn't seems to use obsolete Extent
New description:
these to revise)
Others to test
uDig -
OpenJump (I have just 1.3.1 need to check newer)-- Ad hoc Query tool works
pgRouting -- I think this will have issues too as last version I checked
was I think using deprecated startpoint and endpoint functions among other
things.
Comment(by robe):
Jef, Thanks.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/833#comment:4>
