[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Mon Jan 3 09:05:42 PST 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by mcayland):
 Right - that definitely points the finger at the i18n stuff. Can you try
 the following on SVN trunk:
 make clean
 ./configure
 Then alter the generated loader/Makefile and comment out the NLS flags
 section like this:
 # GetText includes and libraries
 GETTEXT_CFLAGS =
 GETTEXT_LDFLAGS =
 #nls_build = no
 #ifdef nls_build
 #       localedir = $(shell $(PG_CONFIG) --localedir)
 #       CFLAGS += -DUSE_NLS
 #       CFLAGS += -DLOCALEDIR=\"$(localedir)\"
 #       LANGUAGES = fr
 #endif
 If you then do a build, does it work after that?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:14>
