[postgis-devel] [PostGIS] #753: Error in make comments
PostGIS trac at osgeo.org
Mon Jan 3 12:40:36 PST 2011
 Reporter:  aperi2007       |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 compiling on debian Linux 32bit the last version 6560
 I have this error in the
 "make comments" phase
 postgres at deb:~/software/postgis/postgis-2.0.0SVN$ make comments
 make -C doc comments
 make[1]: Entering directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/doc'
 /usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis.xml >
 postgis_aggs_mm.xml
 /usr/bin/xsltproc ./xsl/postgis_comments.sql.xsl postgis.xml >
 /usr/bin/xsltproc ./xsl/raster_comments.sql.xsl postgis.xml >
 raster_comments.sql
 error : No such file or directory
 http://www.w3.org/Math/DTD/mathml2/mathml2.dtd:2126: warning: failed to
 load external entity
 "http://www.w3.org/Math/DTD/mathml2/iso8879/isonum.ent"
 %ent-isonum;
 Entity: line 1:
  %ent-isonum;
 http://www.w3.org/Math/DTD/mathml2/mathml2.dtd:2131: warning: failed to
 "http://www.w3.org/Math/DTD/mathml2/iso8879/isopub.ent"
 %ent-isopub;
 Entity: line 1:
  %ent-isopub;
 make[1]: Leaving directory
Ticket URL: <https://trac.osgeo.org/postgis/ticket/753>
