[postgis-devel] [PostGIS] #302: Drop ST_ duplicate variants of functions underneath TYPE and OPERATOR definitions.
PostGIS trac at osgeo.org
Tue Jan 4 22:00:20 PST 2011
definitions.
  Reporter:  pramsey  |       Owner:  pramsey
      Type:  task     |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I think I got the last of these at r6566 and r6567.  My make checks passed
 at any rate.
 Paul - you'll probably want to double-check to make sure I didn't screw
 up.  I also put in the sqldefines.h in legacy since I figured it needed it
 for your gserialized switch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/302#comment:1>
