[postgis-devel] [PostGIS] #759: [raster] annoying WARNING: Getting NODATA value for a band without NODATA value
PostGIS trac at osgeo.org
Sat Jan 8 22:10:59 PST 2011
value
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 Jorge,
 I think this is similar to the notice you fixed earlier .  Would be nice
 if you changed this one to a debug only notice too.
 When I use gdalwarp like this:
 gdalwarp -s_srs "EPSG:4326" -t_srs "EPSG:2163" PG:"host='localhost'
 port='5440' dbname='test_postgis20' user='postgres' password='whatever'
 schema='ch13' table='usdem'
 where='ST_Intersects(rast,ST_MakeEnvelope(-115.60,32.54, -112.96,
 26.03,4326))' mode='2'" usdem_sub.tif
 It outputs fine but gives me a notice for each tile:
 WARNING:  Getting NODATA value for a band without NODATA values. Using 0
 CONTEXT:  SQL function "st_bandmetadata" statement 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/759>
