[postgis-devel] [PostGIS] #760: Topology fail some checks
PostGIS trac at osgeo.org
Sun Jan 9 09:44:09 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  1.5.X
 Keywords:             |
 Running "make check",
 I'm having some error in topology section.
 the logs report these errors:
  PostgreSQL 9.0.2 on i686-pc-linux-gnu, compiled by GCC gcc (Debian
 4.3.2-1.1) 4.3.2, 32-bit
  Postgis 2.0.0SVN - 2011-01-09 17:48:56
    GEOS: 3.3.0-CAPI-1.7.0
    PROJ: Rel. 4.7.1, 23 September 2009
 Running tests
  regress/legacy_validate. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_1_diff)
  regress/legacy_predicate. ok
  regress/legacy_invalid. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_3_diff)
  regress/sqlmm. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_4_diff)
  regress/legacy_query. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_5_diff)
  regress/addnode. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_6_diff)
  regress/addedge. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_7_diff)
  regress/addface. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_8_diff)
  regress/st_getfacegeometry. failed (diff expected obtained:
 /tmp/pgis_reg_22895/test_9_diff)
  regress/topoelementarray_agg. ok
  regress/droptopology. ok
 Run tests: 11
 Failed: 8
 make[2]: *** [check] Error 8
 make[2]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/topology/test'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/topology'
 make: *** [check] Error 1
 postgres at deb:~/software/postgis/postgis-2.0.0SVN$
 Added a zip with diffs from tmp.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/760>
