[postgis-devel] [PostGIS] #761: Raster: fail some check
PostGIS trac at osgeo.org
Sun Jan 9 09:49:03 PST 2011
 Reporter:  aperi2007       |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 in the "make check" phase I see some error for raster section.
 I'm using a postgres 9.0.2 on a debian 32 bit and the postgis 2.0.0 trunk
 last version.
 I put log here.
 Testing 1BB band
 WARNING: rt_band_set_nodata: NODATA value for 1BB band got truncated from
 2 to 0
 3 to 1
 WARNING: Pixel value for 1BB band got truncated from 2 to 0
 WARNING: Pixel value for 1BB band got truncated from 3 to 1
 Testing 2BB band
 WARNING: rt_band_set_nodata: NODATA value for 2BUI band got truncated from
 4 to 0
 5 to 1
 WARNING: Pixel value for 2BUI band got truncated from 4 to 0
 WARNING: Pixel value for 2BUI band got truncated from 5 to 1
 Testing 4BUI band
 WARNING: rt_band_set_nodata: NODATA value for 4BUI band got truncated from
 16 to 0
 17 to 1
 WARNING: Pixel value for 4BUI band got truncated from 35 to 3
 Testing 8BUI band
 WARNING: rt_band_set_nodata: NODATA value for 8BUI band got truncated from
 256 to 0
 WARNING: Pixel value for 8BUI band got truncated from 256 to 0
 Testing 8BSI band
 WARNING: rt_band_set_nodata: NODATA value for 8BSI band got truncated from
 -129 to 127
 129 to -127
 WARNING: Pixel value for 8BSI band got truncated from -129 to 127
 WARNING: Pixel value for 8BSI band got truncated from 129 to -127
 Testing 16BSI band
 WARNING: rt_band_set_nodata: NODATA value for 16BSI band got truncated
 from -32769 to -32768
 from 32769 to -32768
 WARNING: Pixel value for 16BSI band got truncated from -32769 to -32768
 WARNING: Pixel value for 16BSI band got truncated from 32769 to -32768
 ERROR: Coordinates out of range
 Testing 16BUI band
 WARNING: rt_band_set_nodata: NODATA value for 16BUI band got truncated
 from 65536 to 0
 WARNING: Pixel value for 16BUI band got truncated from 65536 to 0
 Testing 32BUI band
 WARNING: rt_band_set_nodata: NODATA value for 32BUI band got truncated
 from 4.29497e+09 to 0
 WARNING: Pixel value for 32BUI band got truncated from 4.29497e+09 to 0
 Testing 32BSI band
 WARNING: rt_band_set_nodata: NODATA value for 32BSI band got truncated
 from 2.14748e+09 to -2.14748e+09
 WARNING: Pixel value for 32BSI band got truncated from 2.14748e+09 to
 -2.14748e+09
 Testing 32BF band
 Testing 64BF band
 Testing band hasnodata flag
 ./testwkb
  in hexwkb len: 122
 out hexwkb len: 122
  in hexwkb:
 00000000003FF0000000000000400000000000000040080000000000004010000000000000401400000000000040180000000000000000000A00070008
 out hexwkb:
 0100000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144000000000000018400A00000007000800
  in hexwkb len: 128
 out hexwkb len: 128
  in hexwkb len: 138
 out hexwkb len: 138
  in hexwkb len: 152
 out hexwkb len: 152
  in hexwkb len: 152
 out hexwkb len: 152
 ext band path: /tmp/t.tif
 ext band  num: 3
  in hexwkb len: 152
 out hexwkb len: 152
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
  in hexwkb len: 284
 out hexwkb len: 284
 All tests successful !
 make[3]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/raster/test/core'
 make[2]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/raster/test'
 Consider also running make post-install-check after installation
 make[1]: Leaving directory
 `/home/postgres/software/postgis/postgis-2.0.0SVN/raster'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/761>
