[postgis-devel] [PostGIS] #767: Ndims does not exists Error
PostGIS trac at osgeo.org
Tue Jan 11 13:28:17 PST 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 try-ing to execute
 SELECT
 Populate_Geometry_Columns('caricamento._csr_map_crop_multiline'::regclass);
 on a postgis 200 trunk on debian 32 bit (postgres 9.0.2)
 I have this error:
  ERROR: function ndims(geometry) does not exist
   Suggerimento: No function matches the given name and argument types. You
 might need to add explicit type casts.
   Dove: PL/pgSQL function "populate_geometry_columns" line 88 at
 istruzione EXECUTE
Ticket URL: <http://trac.osgeo.org/postgis/ticket/767>
