[postgis-devel] [wktraster] Core tests failure for r5841
Jorge Arévalo jorge.arevalo at deimos-space.com
Wed Jan 12 11:02:04 PST 2011
On Wed, Jan 12, 2011 at 7:47 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
> Jorge, Regina,
> I get a fresh build of PostGIS raster and the regress test in rt_addband.sql fail on my machine. It was modified by Mateusz which was obtaining different results.
> In the first case:
> SELECT St_Value(ST_AddBand(ST_MakeEmptyRaster(1000, 1000, 10, 10, 2, 2, 0, 0, -1), 1, '16BSI', -32769, NULL), 3, 3);
> Mateusz gets 32767 and I get -32768
> In the second case:
> SELECT St_Value(ST_AddBand(ST_MakeEmptyRaster(1000, 1000, 10, 10, 2, 2, 0, 0, -1), 1, '16BSI', 210000.46, NULL), 3, 3);
> Mateusz gets 13392 and I get -32768
> I suspect this is a Windows/Linux difference. Do the test works/fails for you? What results do you get?
> Pierre
In my Linux (Ubuntu 9.10) box:
>From SELECT St_Value(ST_AddBand(ST_MakeEmptyRaster(1000, 1000, 10, 10,
I'm getting -32768
And from SELECT St_Value(ST_AddBand(ST_MakeEmptyRaster(1000, 1000, 10,
I'm getting -32768 too
Using last version from trunk (r6604).
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
>>-----Original Message-----
>>From: Mateusz Loskot [mailto:mateusz at loskot.net]
>>Sent: 4 septembre 2010 14:28
>>To: PostGIS Development Discussion
>>Cc: Pierre Racine
>>Subject: Re: [postgis-devel] [wktraster] Core tests failure for r5841
>>On 31/08/10 21:14, Pierre Racine wrote:
>>>>From thoses two lines in the rt_addband.sql file:
>>> and further:
>>Pierre,
>>I'm still confused why you are getting such strange values.
>>The value -32768 is invalid and unexpected, obviously.
>>It would indicate a bug.
>>Fortunately, I do not get such value, but I get the correct ones:
>>r1=# SELECT St_Value(ST_AddBand(ST_MakeEmptyRaster(1000, 1000, 10, 10,
>>WARNING:  Initial pixel value for 16BSI band got truncated from
>>-32769.000000 to 32767
>> st_value
>>    32767
>>(1 row)
>>210000.460000 to 13392
>> st_value
>>    13392
>>(1 row)
>>Nevertheless, I've updated the expected output with correct values:
>>http://trac.osgeo.org/postgis/changeset/5907
>>Best regards,
>>Mateusz Loskot, http://mateusz.loskot.net
>>Charter Member of OSGeo, http://osgeo.org
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
