[postgis-devel] [PostGIS] #769: [raster] Regression test fails when debug option is active
PostGIS trac at osgeo.org
Wed Jan 12 12:38:22 PST 2011
 Reporter:  jorgearevalo     |       Owner:  jorgearevalo
     Type:  enhancement      |      Status:  new
 Priority:  low              |   Milestone:  PostGIS 2.0.0
Component:  postgis raster   |     Version:  trunk
 Keywords:  regression test  |
 If the option '--enable-debug' is activated in configure time, the
 regression test rt_band_properties.sql will fail, because an unexpected
 debug message is shown:
 "WARNING:  Getting NODATA value for a band without NODATA values. Using
 13"
 How to fix it: checking for debugging variables during regression tests,
 and adapting the expected output in that case. This ticket is opened only
 as a reminder, to implement this solution ASAP.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/769>
