[postgis-devel] [PostGIS] #655: [raster] raster2pgsql -b switch produces bad sql file
PostGIS trac at osgeo.org
Wed Jan 12 13:54:37 PST 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 The problem is the WKB string is created with the number of bands of the
 raster, instead of the band required with the -b option.
 So, if the raster has 3 bands and you specify the option -b 1', the WKB
 string has 3 in the number of bands, instead of 1.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/655#comment:4>
