[postgis-devel] [PostGIS] #762: [raster] Raster some check fails
PostGIS trac at osgeo.org
Wed Jan 12 15:26:16 PST 2011
 Reporter:  aperi2007       |       Owner:  pracine
     Type:  defect          |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by aperi2007):
 I tested. But unfortunately the error is still here.
 executing:
 make raster-post-install-check.
  create_rt_utility_test. ok
  rt_utility. ok
  create_rt_gist_test. failed (diff expected obtained:
 /tmp/rtpgis_reg_11895/test_25_diff)
  rt_above. ok
  rt_below. ok
 I add a zip with the new diff log.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/762#comment:4>
