[postgis-devel] [PostGIS] #413: ST_OffsetCurve
PostGIS trac at osgeo.org
Fri Jan 14 02:15:28 PST 2011
 Reporter:  rafalmag     |       Owner:  strk
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
Comment(by sholl):
 Replying to [comment:19 strk]:
 > See two comments up: documentation + testcase missing.
 > Given all this time elapsed, chances are the code will also need to be
 reviewed for applicability.
 > NOTE: there's a mirror on github now, if you'd find it more useful:
 > https://github.com/strk/postgis
 OK, good to know.
 At least I can document things for this function, but I am unsure which
 format will suffice. Are there some How-to-document-correct-guidelines
 somewhere available?
 Perhaps the original author of the (very useful) patch is able to update
 the patch and provide a testcase? Rafal?
 Thanks.
   Stephan
Ticket URL: <https://trac.osgeo.org/postgis/ticket/413#comment:20>
